How can I set up the Fibaro system to frost protect a water pipe? I want to turn on Fibaro wall plug when the temperature is -1 degrees C and off on 0 degrees C automatically to control the heating cable.
I have an outdoor temperature sensor.
Heating panel could solve this but settings only goes to +4 degrees
Any suggestions?
8 answers to this question
You can make a block scene for this.
Edited by Reinhold
something like this
you can make it more nice, but it should work
@Milan Takacs
He have a lits he can't make lua scenes
Sorry, didn't seen...
Then 2 scene... on for turn on, and one for turn off...
You right @Reinhold
You are right he must make 2 scenes. 1 for on and 1 for off. You can't use else in a block scene.
Edited by Reinhold
    Thanks for help, I had tried this before but used "and" instead of "then"
    I have made 2 scenes now which run automaticly, on and of, hope they will work:
    /monthly_2019_01/image.png.7ce59484506578f25cdfd06a3818392a.png" alt="image.png.7ce59484506578f25cdfd06a3818392a.png" />
    This must work.
    Hi, I have another question on this post, I want to receive a notication  one time when the temperature is under -1 and heating cable switch on, I have set up notification but it send notifications all the time, every few minutes. Is this wrongly set up or will not work or do I have to do something on my mobile to stop the notification after the first one?
    /monthly_2019_01/image.png.45653c08dbb13fd9d1664bb93f87e7e2.png" alt="image.png.45653c08dbb13fd9d1664bb93f87e7e2.png" />
