I have set up a relay switch on my garage door, and also have a Vision ZG8101 angle sensor mounted on the garage door. This works, but the interface is not very "elegant"
Does anyone have any tips on how i could set it up so that i have an "up" and a "down" button, and also indication that shows in a good way if the door is open or closed? I would appriciate all help, my Fibaro knowledge is very basic, and i have little or no experience with LUA and VD.
Guest puma
I just use something like this.
Comes as an all in one. It isn't really 100% supported by fibaro but it does work.
  • 7 months later...
What about the Fibaro Roller Shutter 3? It's designed for garage doors as well.
Fibaro relay switch controlling door and fibaro door sensor for open and closed indication
then vd  or control via scene for phone widget
