P Jonak 0
Hi
I am playing around with HUE together with my Fibaro system and so far it works fairly well. I am able to get my wall switch (with a dimmer 1 behind it) "control" the HUE indirectly via scenes. So I am able to switch the HUE on or off just by pressing S1 on the dimmer. However, if I use the HUE remote the dimmer won't know about it and comes out of sync.
Working example:
- press S1 on dimmer kicks of a LUA script that sends a "on" signal to the HUE light.
- press S1 on dimme again sends an "off" signal to the HUE
Not working example:
- Hue started via the LUA script as mentioned above. If I then kill the light via the HUE remote the dimmer of course won't get a notification of that and still thinks it is "on". To "resync" the two devices I have to press S1 two times again. This of course works but, I would like to get another LUA script to pick up the status of the HUE and set the fibaro dimmer accordingly.
I can see that the HUE light status (on/off) is picked up by my controller if I press the remote so my idea was to use the following code to pick it up and set the dimmer in the same state.
%% properties
145 HUE light
164 Fibaro dimmer
%% globals
if (fibaro:getValue(145, "ui.onOff.value") == '1')
then
fibaro:call(164, 'turnOn')
else
fibaro:call(164, 'turnOff')
But problem is that the script never executes. it is set to automatically start and I can execute it manually to verify it works but I still cannot get it to execute automatically (possible that it does not recognize the on/off trigger on the HUE).
Any suggestion of how this could be done?
And just to clarify, I am not using the dimmer to control the HUE lights directly. I am only using it to trigger the HUE via scripts.
//Peter
Edited by P Jonak2 answers to this question
