Manual Light Switch not working
GavinZA
After connecting the Fibaro dimmer 2 the manual light switch does not work.
the automation works but the manual wall switch does not.
is it supposed to work as normal or does one loose that function once the dimmer is installed?
Guest fat
You should still be able to use a switch as well as the app/automation
Are you able to give a bit more info on the type of switch and any other symptoms you have?
Please check  switch configuration parameters.
Set parameters according to your manual - Momentary, Toggle and etc.
