Krzynio 0
Hello. I have a script adapted by @Auto Frank "Extractor_Fan.vfib". The problem is that it does not change my status from On to Off in the module. Please help. I am enclosing the script from the main loop.
local device = fibaro:getSelfId()
local zone = fibaro:getName(device)
local ipaddress = fibaro:getValue(device, "IPAddress")
local port = fibaro:getValue(device, "TCPPort")
s = Net.FHttp(ipaddress, port)
rS1 = s:GET("/cm?cmnd=Status")
rS2 = s:GET("/cm?cmnd=Status%2010")
if rS1 ~= nil and rS1 ~= "" then
jS = json.decode(rS1)
if jS.Status.Power == 0 then
fibaro:call(device,"setProperty","ui.extfan.value", "Off")
fibaro:call(device, "setProperty", "currentIcon", 1085)
fibaro:setGlobal("SonoffFanGuestEns", 0)
fibaro:debug("fan is off")
elseif jS.Status.Power == 1 then
fibaro:call(device,"setProperty","ui.extfan.value", "On")
fibaro:call(device, "setProperty", "currentIcon", 1006)
fibaro:setGlobal("SonoffFanGuestEns", 1)
fibaro:debug("fan is on")
else
fibaro:debug("Sonoff appears to be offline")
fibaro:call(device,"setProperty","ui.status.value", "OFFLINE")
if rS2 ~= nil and rS2 ~= "" then
jS = json.decode(rS2)
local Temp = jS.StatusSNS.DHT11.Temperature
local Humidity = jS.StatusSNS.DHT11.Humidity
fibaro:setGlobal("SonoffFanGuestEnsT", Temp)
fibaro:setGlobal("SonoffFanGuestEnsH", Humidity)
fibaro:call(device,"setProperty","ui.temp.value", Temp.." C")
fibaro:call(device,"setProperty","ui.humidity.value", Humidity.." RH")
local fanState = fibaro:getGlobalValue("SonoffFanGuestEns")
if fanState == "1" then fanStat = "Off" else fanStat = "On" end
status = ""..fanStat.." / "..Temp.." C / "..Humidity.." RH"
fibaro:debug(status)
fibaro:call(device,"setProperty","ui.status.value",status)
local upt = ""..os.date("%d").." "..os.date("%b").." @ "..os.date("%H:%M")..""
fibaro:log("Updated: "..upt)
fibaro:sleep(5000)
