Guest macciuk
Recently I have bought Shutter Panel Switch from MCOHOME MH-C421 - month ago when installed one of them, everything worked just fine - I was able to set and save Configuration parameters (9 is to calibrate) for one of my Blinds.
Even now - I am able to modify and everthings works just fine for this one blind.
/monthly_2019_03/image.png.f0912b22d285ad0bd8db0437a04d2b5f.png" alt="image.png.f0912b22d285ad0bd8db0437a04d2b5f.png" />[20:55:33] ID 280: Set parameter 9, value = 1
However, when I installed another Switches yesterday - for those two I am no longer able to save configuration. When I click save, there is just page reload and no info records that I would like to set the parameter nor nothing happens:
I have tried to re-install these switches several times, changing their place to be closer to HC2 (even in the same position as working switch) and nothing helps there.
For me it seems that something may change in between this month period in Fibaro HC2. Can you somehow validate this?
4 answers to this question
