Papat 4
Hello folks,
I am a total newbie in the Fibaro domotic system but my humble RF knowledge maybe of help to some of you.
I experienced range issues with my NEO Coolcam plug recently purchased from Aliexpress. After several unsuccessful attempts to reach a plug in a weird location (the socket is surrounded by a big mirror, hence a metallic screen for RF signals), I decided to open one of them to see how the antenna is accommodated in such a tiny shape.
The attached picture speaks for itself... a tiny circular PCB antenna rounded inside for a vertical linear polarized signal... Of course, there is not much possibilities in such a tiny volume but I decided to see what a linear wire of 8cm (1/4th of the wavelength) straight and vertical instead would do.
Guys, the difference is huge! That plug was previously unable to connect to the closest neighbour just located 5m away and now it locks to all other devices of the room! No lag, no lack of connection anymore...
I am presently modifying all my plugs.
If it is of interest to some of you, I will post the step by step mod procedure here.
Edited by Papattypo correction
11 answers to this question
