sarf77 11
Hi all,
I am wanting to use a UBS to trigger an entry and exit scene through an electric gate. The gate is some 30m from the nearest HCL so zwave range will be difficult and unreliable.
If I run a 30m two core cable across IN1 and Gnd out to a magnetic reed switch, Will the UBS still sense the open close contact over that distance? Worst case I could use a 12V relay locally switched by the 30M cable through the mag reed if need be.
