Evgin 0
Hi Everyone!
I'm new here, need some help !!!
Recently I've switched from HCL to HC2 and decided start everything from scratch. Instead of migrating I've manually added all devices. It went almost ok. For some reason 2 x old AEON inwall switches don't work. I can see them in the system but they won't respond. It's a bummer but I can kind of accept that. They are old... (although If I connect them to zwave stick or Vera3 - they still work no problem - just not with HC Lite or 2).
However my main problem now: I can't change parameters on half of my 3rd party devices such as AEON micro double or single switches.
I can manually add parameters but it appears command doesn't get send. For example I need to enable "Report" which is "80" 1D set to "1" - I save it but nothing happens. Like I did nothing at all.
Node is responding well as I can Poll it no problem or can send "Read Only" command on the same parameters or reset to "Default value".
I am 100% sure it worked before as I have done it multiple times on older firmware. Basically now I have to poll 36 devices which is crazy slow while before devices would report if status has been changed. Plus half of the switches now went from "push button" settings to "2 state" and I can't change it via settings.
Please help!!! Perhaps there is a way around such as LUA scripts via Virtual button? I need to change at least 2 parameters urgently on AEON micro double switches: 80 set to 1, 120 set to 0
I have zero experience in LUA, but any help will be much appreciated!
THANK YOU!!!
7 answers to this question
