Stripe68 0
There doesn't seem to be a forum for the Walli products yet so I'll try posting here.
I'm playing with the Walli switch and so far I like it a lot. But there's one thing I can't get working: I want the buttons to send scenes only, they should not change the state of the local outputs. Is this not possible?
I expected that changing config register 40/41 to anything other than zero would do this, but it doesn't. Operating the buttons sends the correct scenes but it also changes the outputs. In my setup I have some locations where I want the switch to only send scenes and the controller should be the only device able to change the outputs.
Is this possible to do? It would give me full flexibility in how I use the switch. It would also enable setups where your have two switches A and B, and you want button A to control light B and button B to control light A.
Maybe an undocumented value in config register 20 to disable the local outputs?
Also, in some YouTube videos showing the Walli product line the Fibaro sales people say that you can set the colour of the indicator LED to any RGB value, but from the documentation it seems that it only supports 7 colours. Not a big thing for me since 7 colours is enough when using it as a general status indicator, but it would be nice to be able to select any RGB colour. For instance, if you use the dim scene to change the colour of a light it could be nice if the LED on the switch was set to the same colour.
/Mats
