EQ74 2
I have problems with Z-uno
Z-uno worked with HC2 for a couple of days, then the channels started to mess.
I fixed sketch many times.
Maybe I installed Z-uno and changed the skecth too many times, and then came the message below.
HC2 NOTIFICATIONS:
Devices without templates
Some devices in your Z-Wave network do not have Z-Wave templates.
If they do not work properly or miss some functionalities, download the device's template and send it to [email protected].
We will prepare the appropriate Z-Wave template to fix the problem and provide full support of the device.
The lack of parameters template does not mean that device is not supported.
You can still add configuration parameters manually according to device's manual using the Advanced Configuration page.
This notification will disappear when all devices will have Z-Wave templates.
I also restored the z-wave settings from Fibaro HC2 and I tried many software versions, now is 4.550
Here is sketch:
13 answers to this question
