HCL in Recovery : how long does it takes ?
Emdeka
I very recently got a brand new HCL. Startup went well. Firmware update to 4550 was ok. Until I created an extra user, using the same email-adress as the superuser. I lost superuser acces.
Contacted support: solution was to go in recovery.
Recovery started. Since more than 6 hours I get the message : "System is going down for a reboot now. Please wait". When I want to exit from recovery : "System busy".
The 3 leds right are burning. I can ping the HCL on a different IP adress. When I want to enter: it blocks. I get a warning mail: security alert, suspicious logon.
How long do I have to wait before "factory reset logon" ?
There was only one device in one room  added.
Any help ?
Thnx
Hello @Emdeka
Recovery definitely should not take 6 hours.
What do you mean that it blocks when you try to enter? Does login page load?
Remember that after recovery your credentials are changed to admin/admin.
Here is what you can do:
1) clear the Internet cache of your browser. The way of deleting cache varies depending on a browser. You can find an instruction here
2) try to access Fibaro with another Internet browser or in incognito/private mode
3) unplug the device from the power for few minutes and then plug it again
4) check whether you Home Center's IP address has not changed after recovery
    Solved by replacement of the HCL unit. W.orks fine now
