Flashing fibaro eye
Kage
from time to time a haven 2 fibaro eye's that are flashing without any reason. All the other eye's doesn't have that
What can this be?
Sensitivity parameter? if it is at the most it could be picking up small movements - what is in the surrounding area?
  • No movements, its in the bedroom and kitchen.
    It might pick up vibration or shock. One of My FGMS is on a cupboard and when I shut the cupboard door it triggers tamper.
    From the manual:
    visual indicator signalling modes:
    1. Motion Alarm colour will vary depending on the temperature. The colour and the signalling mode can be set in parameter 80.
    2. Tamper alarm is signalled with an alternating blinking in LAPD colours (red - blue - white).
    3. The Z-Wave node Info command frame is signalled with glowing in blue. node Info command frame is sent each time the device wakes up.
    4. Menu position is signalled with assigned illumination colour.
    Parameter 20. Tamper - sensitivity
    This parameter determines the change in force acting on the device, that will result in reporting tamper alarm - g-force acceleration.
  • Thx will check and adjust this. Let you now
