Error in diagnosis graphic
hTiger1
Hi
Has anyone seen this error in the graphics.
The error is there when I use my favorite browser, Google Chrome.
The error does not occur in Microsoft Edge.
Restarting Fibaro and computer does not help.
Going back to a previous backup doesn't help.
Edited by hTiger1
5 answers to this question
  • 39 minutes ago, Tony270570 said:
    Hej @ hTiger1  Jeg bruger den samme browser og har ikke dette problem. Har du prøvet at rydde din cache?
    Yes, no change.
    Hi guys I've no clue, I've tried with several hc with different brows?from different PCs and can't reproduce :(  which chrome build do you have? I'm running V 76.0.3809.132. looks to be the last version. Last thing do you have plugins installed?
    EDIT
    Hey ! reproduced. I'm using a plugin called cloud browser (virtual IE6-IE11 browser for chrome) , i switch it off and the issue occurs ! the funny thing is i turned it on again but the problem now remains :) tried to restart chrome but still the same ?
    Edited by Tony270570
    EDIT
    Hi
    I have the same Chrome version as you.
    Too bad you got the same error now.
    Don't have the plugin you mention, and can't find it either.
