CCTV PoE
eserem
Hi
I wired home with cat 6 in every room ceiling for installing cameras, which camera is compatible with homecenter 2 and is at least 1080p?
P.S. 1 cat 6 also outside ( so camera waterproof)
HC2 support only  MJPEG stream, isn't possible to connect direct camera with RTSP stream.
    Ok thx, what could I do to see and manage the cameras, from home center 2? should I buy low resolution mjpeg ip cameras?
    look this topic:
    or check if your cameras have second stream jmpeg or jmpeg snapshot (1s). It's posible to check this in manual or by any onvif tools to find url for snapshot.
