Sjakie 135
Hi I guess after an update it does not work anymore.
Does somebody knows how to correct?
%% properties
%% events
%% globals
if
( tonumber(fibaro:getGlobalValue("Dummy")) == tonumber("0") )
then
local sid, bid = 249, 28 --Sonos player, button
-- Create TTS params object
local params = {
-- TTS Message
message = "Hallo, Here you can put your message" ,
duration = 'auto', -- Duration: "auto", xx seconds
language = "nl-nl", -- Language: fr-FR
volume = 50 -- Volume
local _f = fibaro
local _x ={root="x_sonos_object",load=function(b)local c=_f:getGlobalValue(b.root)if string.len(c)>0 then local d=json.decode(c)if d and type(d)=="table"then return d else _f:debug("Unable to process data, check variable")end else _f:debug("No data found!")end end,set=function(b,e,d)local f=b:load()if f[e]then for g,h in pairs(d)do f[e][g]=h end else f[e]=d end;_f:setGlobal(b.root,json.encode(f))end,get=function(b,e)local f=b:load()if f and type(f)=="table"then for g,h in pairs(f)do if tostring(g)==tostring(e or"")then return h end end end;return nil end}
-- Make a request to the remote to process params object instantly
_x:set(tostring(sid), { tts = params })
_f:call(sid, "pressButton", bid)
bold text give an error
attemptto index local "f" (a nil value)
thanks in advance
//Sjakie
