merten 5052xx 2-way switch reverse/toggle buttons
rflindt
Hi
i have a lot of merten 5052xx 2-way swithces in my house together with Merten 507501 1 channel relays, and i have succefully joined them to my HC lite system. And the setup i found in this forum with setting up the four association groups work fine, im able to connect the swithes to the relays and can control them. But in my old system where they were using the Merten radio configurator, i was able to change the function for the top and bottom switch button, so i was reversed, and now i try to do the same with the HC system, but cant see any option to do this.
I use the standard template added by fibaro HC, as this:
Dual -surface push-button:
Left top button - Association Group 1 / Parameter 0
Left bottom button - Association Group 2 / Parameter 1
Right top button - Association Group 3 / Parameter 2
Right bottom button - Association Group 4 / Parameter 3
The parameter values are defined as follows:
0 - switching/dimming/shutters dual-surface
4 - switching single surface
60 - retrieve/save scene
44 - doorbell function
54 - move shutter single surface (direction changes after each switching process)
52 - lower shutter as long as button is pressed
55 - raise shutter as long as button is pressed
All parameters are set to value 0
Any suggestions how to solve my issue?
