Hi from Belgium - cannot find the HC2 system
Philippecor
My fibaro system is working, sensors, remote controls, so Z-Wave is working BUT i cannot find my system anymore with the Fibaro Finder program.
Can somebody help me with this?
What does the window of Fibaro finder show?
Different IP adress?
Did you try to restart?
@Philippecor Did you put in a fixed IP address?
    No, I did not changed anything.
    When using the program IP scan I can find the device but when I enter this address in my Browser, it is not reachable.....
    Can you ping the HC2?
    Did you try with another PC/Tablet
    Edited by Sjekke
    Can you use the app? if so, direct or home.fibaro.com
    if it's direct check the ip in the app
    did you get a new router?
    do you use dhcp or fixed ip?
