Today my Fibaro smoke sensors are hanging on the ceiling with double velcro tape. This makes removal easy when you need to replace a battery and you don't have to drill holes. Now there are also double-sided magnetic strips specially for (= read non-intelligent) smoke detectors.
Question :
  • Can you also use these magnetic strips for Fibaro smoke / CO2 detectors?
  • Do the magnets have an influence on the operation of the intelligent detectors (z-wave, other, ...).
Greetings,
Sjekke
    FYI
    Feedback from Fibaro Technical Helpdesk.
    There should not be an issue.
    CO sensor is a chemical one and smoke sensor is an optical sensor.
    Magnet should not have any influence on its correct working.
    Chemical Z-wave... ?
    /monthly_2020_01/image.png.be05b5d41bb996ba7fe243bf73c52b37.png" />
    Ofcourse you were asking about connection and they answered about detection...
