IR Remote Control for HC2
FJW
I was looking fora n IR remote control to use with my HC2 but found nothing that suited my needs.
A few weeks ago I came across a linux programm called “TriggerHappy”. Triggerhappy claimed to trigger events for key presses.
Although I am NO linux expert I looked around the internet for more information about triggerhappy and now I have a working IR remote control that does everything I wanted.
If you can control HC2 via api calls, you can control it via triggerhappy. I use “curl” to send the commands.
I had on old Raspberry Pi (I thing model 3) and an extra Flirc USB IR receiver and, of course, a power supply.
The Flirc IR receiver converts ir remote control signals to key presses. This can easily be configured with the software from Flirc.
On the RPI I installed Raspbian Buster, this comes with “TriggerHappy preinstalled”.
The triggers for triggerhappy must be stored in: /etc/triggerhappy/triggers.d and can be any name but must have the extension: .conf. I called mine: remote.conf.
In this conf file you can add all the keys for your remote control. Together with the curl command to execute.
After creating / changing the conf file you must restart triggerhappy to activate the changes with the following command:
sudo systemctl restart triggerhappy
Or
sudo /etc/int.d/triggerhappy restart
On my HC2 I created a Virtual Device with buttons for my remote. I have a “remote” users that only has rights to this VD (but you could also access scenes). Just a safety precaution. I use this user in the curl command.
Now you should have a working IR remote control for your Home Center. I am not sure if it also would work with HC Lite.
Here are a few of my conf file entries: (see TriggerHappy for explanations)
KEY_P   1       /usr/bin/curl -u USER:PWD -S "http://HC_IP/api/callAction?deviceID=309&name=pressButton&arg1=4"
KEY_P is the key on the keyboard, 1 stands for key press and after that is the curl command.
Ctrl End key combination:
KEY_END+KEY_LEFTCTRL    1       /usr/bin/curl -u USER:PWD -S "http://HC_IP/api/callAction?deviceID=309&name=pressButton&arg1=1"
Press VD button:
KEY_SPACE   1       /usr/bin/curl -u USER:PWD -S "http://HC_IP/api/callAction?deviceID=309&name=pressButton&arg1=4"
Call scene:
KEY_F1   1       /usr/bin/curl -u USER:PWD -S "http://KODI:[email protected]/api/sceneControl?id=65&action=start"
 Cheers,
FJW.
So Flirc is not only a receiver, but also a IR transmitter?
Tnx for the howto.
Edited by rvelthoen
