Hello Web Relay
fogmajor
Hello, I am new to the forum and struggling due to my age lol
I wonder if anyone could point me in the right direction after hours of testing and researching
I have a device that controls a relay via HTTP.  I created a virtual device in HC2 and tried both strings and lua without success and a bit of hair loss.
If type into a browser http://<ipaddress>/30000/01  it will turn the relay on
If type into a browser http://<ipaddress>/30000/00  it will turn the relay off
it also works using curl
I am unsure if the issue is that the port is defined after a / rather than a :
Any help would be gratefully received
Thank you in anticipation
Andrew
    Home assistant here I come.
    Edited by fogmajor
    fed up
    Hi Andrew,
    is it possible you provide some more info about that web relay, like model, producer or at least website link? Will be much easier to help you with knowing that information.
