Hello from France
Baptiste
Hello, my name is Baptiste,
I'm 22, i live in France up to Paris.
I'm looking to use my heat controllers with my motion sensors temp. It's possible ?
Regards.
Hi Baptiste
it is possible, if the devices use z-wave. However, z-wave devices can be a bit tricky to use depending on the company that made the device and how the firmware is set up. However, Fibaro Homecenter talks with most devices as far as I know. Do you have problems then there is help on this forum. Welcome!
Hey there,
I have the following devices measuring temperature for my heating:
- Fibaro motion sensor
- Fibaro UBS with BD18B20 temp probes
- AEOTEC 4 in 1
- AEOTEC 6 in 1
All of them report temp fine. They can each be added to a linked device to control the device that turns the heating on.
To turn the heating on, I use:
- Fibaro Single Switch
- Fibaro Double Switch
- Fibaro Relay
All of the above devices work perfectly fine to turn heating on/off
The Switches and Relays either:
- directly power electric underfloor heating for bathrooms
- power an (water based, I think) actuator to allow water to pass through a pipe for both water based underfloor heating and radiators
My heating is working perfectly fine. I can't say I have any faults with it anymore.
