bino 0
https://ebay.us/gj0WmM
I offer a 3D printed mount (material: PLA) for the common Fibaro flush mount actuators. With this tool the module can easily be mounted e.g. in the distribution box or a larger junction box on the DIN rail.
Due to the material used and the openings in the housing, the radio antenna can be positioned perpendicular to the actuator, thus ensuring optimum transmission/reception performance.
The holder does not require any screws, so that the Fibaro module can be removed easily and without damage.
Due to the right-angled arrangement, one of the Fibaro modules requires only about 22mm space on the top-hat rail (allow for about 1.5 divisions).
Due to the mounting bracket, several modules can be placed very easily and orderly next to each other. You can place the Smart Home actuators in a defined and precise position.
The mounting on the top-hat rail is easily done by hooking in the lower bracket and clicking in the upper spring clip (see picture).
Removal is carried out in the reverse order. By pressing the module down, the lower bracket is relieved and can be removed to the rear (see picture).
The adapter can be used with all modules of a size of 42.5 mm x 38.25 mm x 20.3 mm, e.g.
- FGS - 212 (Single Relay Switch)
- FGS - 222 (Double Relay Switch)
- FGS - 213 (Single Relay Switch 2)
- FGS - 223 (Double Relay Switch 2)
- FGR - 222 (Roller Shutter 2)
- FGR - 223 (Roller Shutter 3)
- FGRGBWM - 441 (RGBW Controller)
The delivery includes a 3D printed adapter. The Fibaro module and DIN rail shown in the pictures are for illustration purposes only.
The shipment is inexpensive as uninsured letter post.
Please contact us if you have any questions.
