theplayernll 0
I have some Qubino dimmers.
I can use the wall switch or by HC2 app to turn the lights on and off.
When swithing light on/off using HC2 mobile app, everything goes OK.
But when I use the wall switch manually to putt the light on, it show it's on, put it off and it still says it's on in the app or HC2 panel itself.
So manualy switching it on goes correct, when i switch it off is still says its on in app and HC2 panel.
I am using Fibaro HC2 firmware version 4.580.
All the rest is working fine. Can I do something so this works?
7 answers to this question
