First time user HC3
Hi.
I've just installed hc3 in my house, replacing a hcLite.
After 2 days, i think that the Lite was better.
Hopefully with this forum i can find out what i am doing wrong.
You’re making us curious
    I'm just afraid that it is to advanced for me because i'm not a programmer, and block scenes is more my thing. And nothing works now that I switched to hc3, so hopefully after reading up here in the forum i can learn to use it properly.
    The forum has a lot info. You will get your HC3 running, no worry. Take it step by step.
    Guest Freddan67
    What is your problem ?. Tell us we'll see if we can help you with anything.
    I got all components registered on the hc, and make scenes, but the 2-channel scene button is not working. And it doesn't seem to be a function to if you can see when a switch is activated, as it was in hcLite.
    I've got 2x scene-switches, and both are registeret, but will not work when activated.
    Also 1 dimmer switch worked for some hours, but now has no connection, but the dimmer works manually. I deleted it, and now i can't reconnect it.
    I am seriously considering connecting hcLite back up, since i've got that working on the first try...
    Guest Freddan67
    What is it? I had something similar with fibaro keyfob. A factory reset and then they worked, give it a try
    Try again the "remove device" function of the dimmer in the HC3.
    Even it's not included, you can do an exclusion at all time.
    Maybe it didn't do a proper exclusion.
    Then include again.
    Edited by Flash
