New User HC3
Hi Everybody,
I have bougth the HC3 with some Smoke detectors, door sensor and a wall plug.
The wall plug I want to make scene so I can active my swimming pool heating.
I have created a block scene with some parameters but here is my "problem"
The wallplug can only be on between 10:00 and 20:00 on sunny day's with a temp >= 24 Celsius.
I cant find an interval as i dont want the heating on all the time. Can someone tell how i can create and interval with 15 minutes on and then 15 off all way to 20:00
Thanks.
without any test, something like this could work:
- in time range between 10:00 and 20:00 and
- temp higher/equal than 24 (but don't trigger on temp) and
- trigger (since today 00:00) every 30min
do
- turn on wallplug and
- do delay 15min
- turn off wallplug
/monthly_2020_07/image.png.9ac068cb2364ae4377df03e63de67820.png" />
EDIT: there is some "time drift" possible if your HC3 is busy doing other things, in LUA and combination with QA this could be better timed, but still, should be fine for your reqs.
Edited by tinman
    Cool. Thanks! i will try it.
    It works like a charm. Thanks for your help. Now it will be time to mod it agian with water temp. senors. Let the fun begin.
    Edited by Spetznaz-NL
    should be easy, as you now know to concept behind
