The Emil 0
I have a similar Fibaro challenge as the guy in this forum:
I have a Shelly H&T (Hygrometer and thermometer) with open API that I want to include in my HC2 as a Virtual Device. The Shelly H&T supports a Report URL (GET) that I can configure in the web interface. But according to the documentation it will report humidity and temp as Querystring parameters. (
) sais it will report with the format (/?temp=999.99&hum=100) - appended to the report URL I guess. It is also a GET-call and I can not configure it as i want.So can I fetch these variables in HC2 somehow with LUA code?
Another way to do this is to fetch the values from the Shelly H&T with a HTTP-call from Fibaro. The problem with this approach is that the Shelly H&T is in sleep mode whenever it is not reporting data. So I guess it is awake appr. one second every 10 minutes or so. I have not tried the approach of letting Shelly H&T start a scene in Fibaro that fetches the data via the /status open api. I'm not sure how long it is awake after reporting data
