I can't connect to my HC3 anymore
juju
Hello
I have a problem, following a reboot of my HC3
the inernet light is red.
fibaro finder does not detect HC3
I have tried several times to Reset network settings but nothing helps.
can you help me? thanks.
Hi @juju,
Have a look in you're router network list.
Maybe you can find it's Ip-adres there.
The Fibaro finder works at my place only when i'm in the same subnet.
If you set a static IP adress for you HCx and you make sure that you're router will asign also this adress to the HCx you will alway's be able to reach tthe HCx even if its back on DHCP..
My router setup is
Static IP-adresses. 192.xxx.x.1 till 100.
DHCP adresses       192.xxx.x.101. till 250.
So if my HCx  is offline. No other device will get the HCx adress.
If my HCx gets back online it has its fixed IP or will get his old adress signed back to it.
Edited by Flash
