Hello All!
DariuszP72
Hello All!
I am new here. I have just started with HC3 testing few basic sensors and options. Therefore first question: how to set up the Push notification with the date and time stamp? I want to have info when the event was triggered as the access to the network from the smartphone can be lost. I guess it has to be done via Lua Scene programming. Somebody has a quick suggestion for settings?
Please advice where to start to learn Lua Programming.
Cheers
Dariusz
Welcome
You made the right move, registering to this forum. There are lots of solutions already on this forum.
Also take a look at the manuals, like
and
And creating a block scene and converting it to Lua also helps to start and understand.
Edited by SmartHomeEddy
    Thanks for quick reply. I will study this in more details. For the moment I am learning by making Block Scenes and then converting them to Lua :-) But in this case I am missing this element. Below what I have on Action side:
    fibaro.alert('push', {[1] = 2, }, 'Toggled')
    So I get information: "Toggled" which informs me about specific even. What to add to this script to get info about time eventually also a date? In this case I would like to get a Push notification as per example: Toggled at 13:19 on 17/08/2020. Do you think it would be possible? If yes, should it be a script on Action side modified or Conditions?
    By the way what is the meaning:  {[1] = 2, }?
    I apologize if I ask for too much.
    Dariusz
    I think your looking for this Lua code
    The number 2 is the ID of the user you want to send the notification to.
    GREAT! It works. Thanks a lot! I see there is still a lot for me to learn, but step by step...
