New to Fibaro HC3
Hi All
Have jumped head first into the Fibaro and wired up the whole house with Fibaro devices and HC3. (circa 50 devices)
Looking for some guidance and hopefully some recommendations of fellow users that I can hire to help me with coding. I have the ideas, just no idea how to code them and it looks like there is some limitations with the scene creator.
Looking forward to the journey and advice.
Cheers
Welcome !
A lot of info and products on this forum ?
Hi @AshleyJoseph
I would recommend you to download and install the QA (Quick App) EventRunner 4 which has many posts here on the forum.
Then you only need to write fairly simple rules for how your home automation should work. EventRunner 4 handles most of the things you want to do with your home automation.
-- BEDROOM LIGHT #######################################
  rule("@06:46 & sunrise > 06:46 => bedroom.lamp:on")  -- Turn on the light, but not if the sun has already risen
  rule("@sunrise => bedroom.lamp:off")          -- Turn off the light when the sun rises
  rule("@sunset => bedroom.lamp:on")    -- Turn on the light when the sun goes down
  rule("@22:30 => bedroom.lamp:off")    -- Turn off the light in the evening every day of the week
or turn off the light at different times of the week
  rule("@22:00 & wday('mon-fri') => bedroom.lamp:off")   -- Turn off the light 22:00 Mon - Fri.
  rule("@23:30 & wday('sat-sun' )=> bedroom.lamp:off")   -- Turn off the light 23:30 Sat - Sun.
Edited by RH_Dreambox
    Thanks @RH_Dreambox
    Apologies if this is listed somewhere, but how actually do I add EventRunner 4 and then how do I/where do I start to add the rules like the above example?
    Brief explanation...
    Download QA EventRunner4
    Open Settings 5. Add Devices and choose Other
    Upload File (EventRunner4.fqa)
    Open QA EventRunner4 / Edit & preview / Edit
    Then open "main" in the list to the left on screen
    Main is the only file you need to edit, the other files are the very heart of EventRunner.
    In HT (HomeTable) declare your devices, see my HT below (some swedish words)
     HT = {
          bedroom = {lamp = 46, dim_lampa = 156},
          arbetsrum = {rh_jul = 75, rh_dim = 135, yh_lampa = 85},
          hall = {lampa = 181},
          v_rum = {lampa_east = 11, lampa_south = 13, TV_lampa = 23, laslampa = 25, banklampa = 87, barlampa = 7},
          kitchen = {lamp = 15},
          bodega = {lamp = 231},
          tvattstugan = {tvattmaskin = 66, torktumlare = 68, golvvarme = 58},
          hobby = {MK3 = 83},
          garaget = {takbelysning = 206, vagg_ute = 202, jul_gavel = 64, elstangsel = 144, brytare_uterum = 27},
          storgaraget = {lampa = 9},
          greenroom = {led_slinga = 121},
          sensor = {katt_pir = 212, garage_pir = 110, garage_dor = 210, garage_temp = 111, garage_lux = 112, garage_fukt = 113},
          minimote = {sov = 19, vard = 21},
          phones = {rh = 49, yh = 151, paddan_app = 140, rh_app = 145},
          scen = {vakna = 4, godnatt = 7, auto_light = 14, TTS = 9},
    Then create your rules.
    -- KITCHEN LIGHT #######################################
      rule("@sunset => kitchen.lamp:on")
      rule("@22:30 => kitchen.lamp:off")
    And do not forget to read the thread about EventRunner 3 and 4. ER3 is intended for HC2, but the rules should work in both ER3 and ER4.
     HT = {
          hobby = {MK3 = 83},
    Just uploaded a new version v0.5fix8
