Moved house, new router, static IP, no internet access
Lowdens
I bought a HC2 approx 6 months ago in preparation for a new house build in which I have wired in a lot of Fibaro light switches.
I set the unit up at my previous house to test, wired up a singe light and everything worked fine.  At this point I also set up a static IP.
I then boxed up the HC2 whilst I waited for the build to finish.
Fast forward 6 months and I am ready to install at the new house.  New router.  When i power up I only get the first 2 lights (power and LAN and no internet)  Fibaro finder gives me an IP address that will not connect, so I cannot access the interface.
From reading the forum I think the issue is with the static IP.  Tried re-booting several times, no joy.
Any suggestions on how I can get back into my HC2?  I cannot remember the IP address I was using before and I no longer have the previous router.
Because I only ever connected 1 switch, I am happy to restore the HC2 back to factory and start again - but I'm not sure how to do this?
Thanks,
Stuart
Hi, if your IP =  192.168.81.1 you need to connect your cumputer with ethernet cable to HC2.
Set IP computer on same IP range and connect.
Now you can change IP of your HC2
Good luck,
//Sjakie
Thanks,
Stuart
Press the + button for a second or two, to put it back in dhcp....
Actually I think pressing the + button puts it back to 102.168.81.1. Then connect your PC directly to the fibaro, per @sjakie, where you should be able to login and change the ip settings to whatever you need.
No need to factory reset. ?
It switches to dhcp or static.... And back :)
Step-by-step guide
Physical change
Press and hold the “+” button on the Home Center casing:
  • If diode on the Home Center is flashing fast, it means that static IP is set (192.168.81.1 by default).
  • If diode on the Home Center is flashing slowly, it means that dynamic IP (DHCP) is set.
Thanks, I learnt something. When I once accidentally set my HC2 to fixed IP, it took me ages to fix. I could have just pressed the + button again!
