Hcl and hc-2 offline issue while power is on
A_diaa
I got an issue with my controllers both hc-l and hc-2 , the controllers get offline and all LED lights are off although the power and network cables are pluged in and the ethernet port led indicator is flashing . Any ideas how to fix this issue as all my controllers are updated to the last versions
@A_diaa
if this happens, wich lights are lit at the hc2?
can it be a failing switch?
    @akatar all lights were of and the controller was offline from the network although the ethernet light at the back of the controller was lighted up .... all i did is removed the power and put it back in the same power socket and it was back online . This case happened with me with different controllers not the same one . Any tips ?
    It sound like the controllers crashed
    is youre internet unstable?
    is youre power unstable?
    @akatarThanks for your fast response  ,no both are okay ... i faced this case in more than three different projects I installed.
    @A_diaa The hc2 i had, and sold a long  time ago, crashed every couple of days
    The only thing you can do is contact fibaro support and hope they will have a look, perhaps thay can trace a error log or something like that.
    @akatarokay thanks a lot , i will contact fibaro support hope it works .
