Recovery for my home center lite
elmermahayag
Hi guys. anyone can help me i have home center lite during you make reset the give you a message image file is malformed.
@elmermahayag
Take a look overhere -->
    @akatar thank you I solved the problem. But one thing Why the Ram for hcl is 85%? It should be in lower % because no more programs inside the home center lite because I've done resetting.
    Edited by elmermahayag
    did you upgrade to the latest version?
    • 8 months later...
    Yeah upgraded in latest version but ram still in 90%
    there is nothing wrong with the free memory, it is like that on HCL. In principle linux would take the other 30% (which you see as cached), if necessary, to run new tasks, and only if that didn't work use "fresh" memory. Running processes will btw. stop wroking on HCL when you over 95% or so.
