AutoFrank 372
Shelly relays: 1/1PM/2/2.5/4Pro
http://[deviceIP]/relay/[channel]?[command]&[command]
if you use authorisation sintax is:
http://user:pass@[deviceIP]/relay/[channel]?[command]&[command]
Channels start from 0, that’s mean Shelly2.5 have channel 0 and channel 1 for Output1 and Output2.
Will switch output ON.Please login or register to see this link.
Will switch output ON for 10 sec.Please login or register to see this link.
Will switch the output On if OFF or vice version.Shelly rollers : 2/2.5
Will open the rollerPlease login or register to see this link.
Will opening 5 seconds.Please login or register to see this link.
Will Open at 30%Shelly Bulb/LED/RGBWW/RGBW2
The main command to contorl them is:
http://[deviceIP]/color/0?[command]&[command]
Will switch device ON and set Red, Blue, Green and White colors.
Will swithch device ON and set only WhitePlease login or register to see this link.
Will switch device ON.Please login or register to see this link.
Change the intensity or RGB to 27%The main command to contorl them is: http://[deviceIP]/white/[channel]?[command]&[command]
Will set intesnsity 70%.Please login or register to see this link.
Will switch device on and set intemsity to 70%Please login or register to see this link.
