I want to deactivate (turn off) and activate (turn on) a scene in a scene in HC3.
In HC2 I used lua fibaro:setSceneEnable(sceneID,enabled). It looks like this command is not available any more.
Do you know how this works in HC3.
Thanks for the help.
Kind regards
Huub
    Hi RH_Dreambox.
    Thanks for the response. This I knew but I wont to do it in a scene and not by hand. But thanks anyway for your responce.
    Hi Jgab.
    Is a am a beginner, I read your code as follows,
       define a function (you showed two of the), and than call this function.
    Am I correct? I will test this later today and will keep you informed.
    Thanks for this.
    Yes it will be like the function you use on the HC2 but with a '.' instead of a ':'
    • 4 months later...
    On 11/29/2020 at 10:19 AM, jgab said:
    This is for use in a QuickApp, is there a possibility to use in Lua code on the HC3
    The code fibaro.setSceneEnable(11, enabled);  don't work.
    Who can help.....
    Who can help.....
    fibaro.setSceneEnable(11, true) -- enable
    fibaro.setSceneEnable(11, false) -- disable
    Tested, but nope, didn't work
    So do you get any error message?
    If I run a scene on the HC3 with
    it works very well - disabling and enabling the scene.
    Note that if a scene disables itself it will return  an error (because the scene is interrupted), but it will still become disabled.
    A disabled scene can of course not enable itself...
    The code; fibaro.setSceneEnable(11, true) -- enable ore fibaro.setSceneEnable(11, false) -- disable did nothing when you run this in the Lua, also no error.
    This new coded above tested and this works great in Lua:-)
    Last question; is it possible before you switch from true to false, ore false to true, you get the value from this scene number
    Example; in a scene you get first the value form the scene, when scene is false you set to true
    In HC2 I use:
    local Timer == fibaro:getSceneRunConfig(119); )
     if Timer == "MANUAL_ONLY" then
          fibaro:setSceneRunConfig(119, "TRIGGER_AND_MANUAL");
     else
         fibaro:setSceneRunConfig(119, "MANUAL_ONLY");
    Thx for you help.
    Have a look at this document compiled by @knuth
    I think I found it.....
    (I like examples:-))
    local debug_TAG = "STATUS_SCENE"
    function fibaro.isSceneEnabled(sceneID)
        return api.get("/scenes/"..sceneID).enabled
    if fibaro.isSceneEnabled(5) == false then
      fibaro.debug(debug_TAG, "scene 5 is false")
    else
      fibaro.debug(debug_TAG, "scene 5 is true")
    print(fibaro.isSceneEnabled(5));
    • 1 year later...
    there is another thing about this concept
    in the scene api stands isRunning=true(or false) en enabled=true(or false) the same thing☺️ but isn't better if the scene is running tru a setTimeOut and gives that a isRunnning=true(or false) en only enabled if it is only enabled or not.
    i experience that when my HC3 restart after a manual restart or some unidentified restart the scenes that are automatically running not running. An there is no why to see this!
