Building Fibaro Cabinets with dinrail modules
Peertje
Hi, Does anyone have experience building a cabinet with dinrail modules with Fibaro dimmer/relais. I have a project with 4 cabinets with about 25 dimming modules per cabinet. I know about the Din-rail adapters but what is inportant reguarding cabels, cooling, spacing, and other stuff ??? Like to hear your thoughts.\
/monthly_2020_12/2071488306_cabinetfibaro.jpg.847f3cadf14af3647adebf7ed2c4fa9b.jpg" />
  • 1 month later...
  • 1 year later...
On 1/29/2021 at 11:00 AM, MarcoSmartForYou said:
hi, if you found a solution pls share it,
it would be a great thing!!!!!!
tks
There is a solution (as you can see in picture above)
You can order from Fibaro distributors
@Peertje @MarcoSmartForYou @Milan Takacs  and other... :)
I have now discovered this question.
The introductory balance sheet and especially the cooling is correct.
While the spacing of the Zwave module might not be large in terms of signal interference / spreading, the opposite is true in terms of warming. In particular, dimmers will have significantly higher heat losses than any relay module.
When installing switchboards, it is necessary to start the feeling of so-called warming.
After all, this is also stated in the valid version of the standard EN 61439-1: 2009, which has been adopted in our country under ČSN EN 61439 in several editions.
What is in the picture, ie the set Eufix, 2x Relay, Eufix, 2x Relay ... will ensure local cooling of the module. You will also need to calculate the total warming of the cabinet at the manufacturer's given heat transfer capacity.
It is often a neglected thing that can have all the consequences.
