implementation of Everspring EH304 floodlight on HC2
Theo
I have connected with reasonable result the floodlight on the HC2. See manual in att.
When you pair it you will see a PIR-sensor (movement) and a lightlevel sensor as new devices. When connected to the HC2, the physical knobs on the floodlight are disfunctional.
So we have to configure these. The manual is not completely clear to me. Here is my interpretation:
1:2 bytes: light on timer [sec]
2:2 bytes:light level limit for PIR activation [lux]
3: 2bytes:reporting cycle [sec]
With "add parameter" you can set these without problem.
There is no on/off switch
You can set the light permanently on with a single line lua command:
fibaro:call(fibaroIDnumber,'turnOn');
The same for "turnOff" which is actually the automatic (standalone) mode.
I made a nice VD, see att.
The maximum reported light level is clipped on 250 lux, but I use it to open the curtains in another lua.
There is also mentioned a notification report in the manual. Can someone explain how to retrieve that?
Thanks in advance.
Hello Theo,
I can't explain that.
I also bought an Everspring EH403 floodlight. I control it with Fibaro HC3.
Lux and motion work perfectly. Parameter settings also work okay.
Only I cannot switch the lamp on /off manually. Does anyone have QA or Lua script to do that?
Thanks.
