ADAX WiFi panel heater integration into HC3
Dear Fibaro Community Members,
I have purchased HC3 recently an am a newbie with it.
I was wondering if it was possible to integrate a WIFI radiator ADAX NEO WiFi (
) into FIBARO HC3 and control the panel heater as remote WiFi client from HC3
I have this available:
a) IP address of the device in my network:
b) ADAX Remote Client API User Guide:
 with Python code samples and JAVA code samples
c) My REST API authentication credetials for the device
d) my Acoount ID
Do you think it would be possible to add such device into Fibaro system and be able to:
- read heating target temperature from the device
- read current temperature from the device
- set the heating target temperature
If possible, I would appreciate some navigation or help with this how to add such virtual device into fibaro system.
Thanky you very much,
Peter
8 answers to this question
Hi
I have made the Adax addon for Fibaro, it will be finished today.
    Sounds great eb1982
    I would be happy if you could upload it and send me the download link, unless you want to place it on fibaro market or download section.
    Currently, I am using workaround with Alexa skill for Adax, but that only supports manual mode, I cannot set "away mode" whilst keeping the week heating schedule.
    Thank u,
    Peter
    Hello. I also need this addon. Is it available for download somewhere?
    I have made a code to get actual temperature now, but I am struggling to set target temperature.
    Anyone?
    Hello
    Have someone a working code for the Adax WiFi and are willing to chare the codeP
    Best Regards
    Henrik
    Guest shoyheim
    Anyone?
    Hi Trygve,
    Did you get this working? I would also like to get this working... Haven't started coding anything on this yet, so if you have something you would share?
    Yes. I have shared this with another Henrik J, and he have improved it. However I havent tried his version yet.
    I share my version, then you could ask Henrik J for his version.
    First I have a scene thar runs every day for updating Token. Username and password must be inserted where code is ¤¤¤¤.
    -- Username can be read in account-tab in Adax-app
    -- Password is generated/found in account-tab/3rd-party integration/Extern API/
    I have pasted the token scene below. I have also attached 2 QA's for monitoring/controlling. One of these need to replace ID of your heating device.
    DECLARATIONS (Conditions/Triggers):
      conditions = { {
          isTrigger = true,
          operator = "match",
          property = "cron",
          type = "date",
          value = { "30""00""*""*""*""*" }
      operator = "all"
    ACTIONS
    -- Renewal of access token needs to be done daily
    -- This scene is run 00:30 every day.
    -- Token is stored in Global vaiable "AdaxToken"
    local http = net.HTTPClient();
    -- Define payload for Adax
    -- Add Username and Password
    local payload = 'grant_type=password&username=¤¤¤¤¤¤&password=¤¤¤¤¤¤¤¤¤¤¤¤¤¤¤¤';
    --API.POST to Adax
    http : request('https://api-1.adax.no/client-api/auth/token',  {
        options = {
            method = "POST",
            headers = {
                   ['Content-Type'] = 'application/x-www-form-urlencoded'
          data = payload
        success = function(response)
        --fibaro.debug(response.data)
        local result = json.decode(response.data);
        local Token = result.access_token
       --fibaro.debug (Token)
       fibaro.setGlobalVariable("AdaxToken", Token)
        end,
             error = function(err) fibaro.debug ("Error:" .. err)
      conditions = { {
          isTrigger = true,
          operator = "match",
          property = "cron",
          type = "date",
      operator = "all"
    ACTIONS
    --API.POST to Adax
        options = {
            method = "POST",
            headers = {
          data = payload
        end,
    Anyone som could bild samme for hc2?
