HC2 and HC3 automatic scenes not running
I found a problem with HC2 and the new firmware (4.620). Also tested on HC3 and has the same problem.
We made an automatic run scene (max. run in. 10) assigned to variables ( the variable works fine). We tested the scene and it worked fine ONCE and than nothing happened. It seems it can not run over and over again, despite the fact that the conditions of the scene are true.
Any idea what can cause the problem?
It will help if you post the scene and conditions
    Thanks, I finally solved it about 2 minutes ago :D :D
    Perhaps you could post what the solution or mistake  was as a learning curve for others?
    //Sjakie
    • 7 months later...
    hi piszker I have the same problem. how did you solve it? could you share thanks
