Walli dimmer without load
beka
I'm sure it's somewhere on the forum but I can't find the right solution.
I want to use 1 walli dimmer without load in an association with another walli dimmer (with load).
The led of the 1st walli dimmer stays in red color mode (Calibration failed: lack of connected load or connected light source exceeds maximum power).
Is there any way to disable this color?
I don't prefer to use a bypass due lack of space.
You can’t use dimmer without load or bypass as load. If you want to synchronize the behavior of your dimmer with load you need to use a walli switch and associate both together.
Hi @beka,
I would use Walli Switch for associations with Walli Dimmer that has loads. It has Associations groups 3 and 5 (multilevel switch), so you can dimm other Dimmers with it.
Only one thing before inclusion is to set it to single output mode for UP to turn on and DOWN to turn off.
