Third party device Mcohome MH8-FC
We set a value for the thermostat after the reach the room temperature the valve will closed and the fan continues working  but now the issue here it should be the Ac keep working all the time I mean the valve should be working all the time if you set manually. For example I will set the temperature into 21 degree celcuis after how many minutes the reach the room temperature 21 degree it should be the valve not stop even  the AC reach the setpoint. How we can solve this issues. Thanks
