FIBARO System Update 5.071 BETA for Yubii Home
K.Drozynski
/monthly_2021_06/aktualizacja.jpg.9a37bd6539f7e6015802d99a7e9a0331.jpg">
Dear users,
We would like to announce that the latest 5.071 BETA is now available.
The update introduces a number of significant features and fixes.
Before proceeding with the update we highly recommend that you read the "Important Notice" section carefully.
In case of any additional questions regarding the update, do not hesitate to reach our team via [email protected]
Important Notice
The following software update contains a lot of new features to enhance the capabilities of your system.
Due to the number of changes, we recommend installation only for advanced users and installers.
Update 5.071 includes a new version of the Z-Wave software (called Z-Wave 3.0). This version features expanded default device support, the ability to add products using Smart Start technology and many other changes. Please note that this is a beta version and its compatibility will be developed with further updates - not all Z-Wave devices are fully supported**.
ATTENTION - installing version 5.071 does not automatically change the existing Z-Wave 2.0 software to 3.0. In order to run version 3.0, it is necessary to restore the gateway to factory settings, requiring the system to be configured from scratch. In future updates we will work on extended device support and provide a mechanism to migrate your current system configuration to the new Z-Wave engine.
Main features:
1. Z-Wave Software 3.0
New Z-Wave engine version 3.0 - in order to use it is necessary to configure the system from scratch. Currently it is not possible to migrate the system in version 2.0 (current) to version 3.0 (new).
Version 3.0 includes the following changes:
  • Simplified mechanism for adding devices (Smart Start).
  • Support for improved encryption mechanisms (Security S2).
  • Streamlined process of advanced device parameters configuration.
  • Possibility to update device software from a file.
  • Extended compatibility of Z-Wave devices (more devices, additional features).
2. Yubii Ecosystem (Home Center 3 & Yubii Home)*
Changes to the Yubii Ecosystem device support:
  • New features related to operating speed for selected devices (also available from block scenes and notifications).
  • Support for further Nice devices.
We have started working in early access to support Elero devices in the Yubii Ecosystem:
  • First, test feature for adding devices to the ecosystem (support for roller shutters only).
  • The functionality is under development and may be significantly modified in future updates.
3. Energy Panel
The first part of functionalities we are providing in the brand-new Energy Panel:
  • Eye-catching energy data visualisation interface.
  • Preview of energy data generated by devices using renewable energy sources.
  • Preview of individual and aggregated data related to energy consumption at home.
We will add further functionalities in upcoming updates.
4. Gateway Connection
We have introduced a mechanism for linking HC3L and Yubii Home gateways. It is possible to connect a master HC3 with HC3L or Yubii Home, which operate in slave mode. This allows to create a smart home system based on HC3, HC3L and YH products. Please note that the master panel can only be HC3. Note - linking of control panels only works within the Z-Wave 2.0 engine.
What's new:
Access
Tooltip with description on user synchronization button.
Alarm
Brand new alarm control dashboard, available to any user.
Possibility of arming and disarming individual zones and the entire house.
Information on the zone tile how much time has elapsed since arming/disarming/alarm.
Backup
Column with backup size information.
Information in api about the Z-Wave engine version on which the backup was created.
Warning before restoring a backup created on a different version of the Z-Wave engine.
Dashboard
Icon in the header indicating that there is no internet connection.
Device limit on YH/HC3L replaced with a recommendation of their maximum number.
Devices
Notification of required device reconfiguration after its updating.
Possibility of interrupting a queued device update process.
Possibility to set a favourite position for grouped roller blinds.
Refreshed Z-Wave configuration parameters support if selected the new Z-Wave engine.
Info on the Advanced tab about the security level the device was added with.
Marking devices added in security mode with a lock icon.
Increased the limit of 20 characters for the device name to 60 characters.
Improved operation and support of power and energy meters.
Added support for upcoming firmware updates of FIBARO Heat Controller (FGT-001).
Support for FIBARO Smart Implant (FGBS-222) version 5.2.
Changed the default icon, role and category of the Rehau RE.GUARD device.
Elero in early access - test functionality*
New category of devices in adding process.
Pairing of Elero devices possible with the new adding wizard.
Energy
Brand new energy panel, available to any user.
Support of devices that consume and produce electricity.
Display of production, consumption, and energy balance for selected time period.
Comparison of the energy balance for the last three time periods.
Top three devices that consumed the most energy during the current time period.
Detailed energy consumption data displayed by room or device category.
Filtering of detailed energy consumption data by room or device category.
Gateway Connection
Possibility to use Yubii Home and Home Center 3 Lite as slave gateways.
Adding and removing devices on connected YH or HC3L from the master gateway.
Possibility to add slave gateway connected to subnet used by master in Wi-Fi connection.
Blocked connecting of gateways with new version or different versions of Z-Wave engine.
General
Possibility of setting m/s as a wind speed unit.
Accepting global variable values longer than 20 characters.
History
Enlarged clickable area on the button with information about new events.
Nice*
Support in scenes for actions with specified roller blind movement speed.
Notifications available as scene triggers.
Notifications
System notification for possible scene update when wind speed unit has changed.
Other
Saving the name of device or scene after pressing the enter key.
New, Danish language version.
Plugins
Added Husqvarna Automower plugin with support in scenes.
Quick Apps
New variable type - secret variable, designed for passwords.
Scenes
Capability of creating multi-line messages for e-mail and push notifications.
Z-Wave
Possibility to select the Z-Wave engine version after resetting to factory settings.
Bug fixes:
Backup
Unexpected new line character in backup description.
Cameras
Image from a camera using digest authentication does not arrive via e-mail.
Preview tab is not active after saving the paths and address of IP camera.
Dashboard
Negative values greater than -1 are displayed as positive.
Devices
Changing the temperature sensor belonging to linked device does not activate the heating.
Door lock may be in wrong state right after being added.
Inverted state logic for door lock custom icons.
No possibility to configure endpoint as output when configured as input before.
FIBARO Walli Controller (FGWCEU-201) does not work in security mode.
Incorrect value of parameter 14 for Heatit Z-TRM2fx.
History
No icons and labels for some events and actions.
No units for values reported by multilevel sensors.
Network
Access Points of the same network are displayed as separate Wi-Fi networks.
Wi-Fi network unexpectedly disconnects, and gateway retries to obtain an IP address.
Nice*
The stop action for grouped roller shutters does not work.
No possibility to add a device for which the adding process was interrupted earlier.
Error when trying to control several shutters simultaneously.
No translations for notifications in block scenes.
Other
Tooltips do not disappear automatically and cannot be closed by clicking on them.
Swagger is available via remote access but is useless.
Plugins
No display of data stored in the Dahua plugin.
Unable to trigger a scene via Satel alarm outputs.
Some Sonos devices are not discovered by the plugin.
Blocked UDP ports prevent the detection of some devices on the network.
Profiles
Buttons of Quick Apps which are available in scenes are not available in profiles.
Quick Apps
UI elements do not refresh when changing properties.
Action setColor does not update the colour property of colorController device type.
Scenes
No possibility of creating scene with action for group of devices.
Incorrect interpretation of home arming status based on the status of the partition.
Update
Insufficient timeout for requesting gateway update status.
Known issues:
Energy
The energy related data collected so far does not appear in the new energy panel.
** New engine 3.0
  • FIBARO Heat Controller (FGT-001) is not functional in this firmware version - only with engine 3.0
  • Not all Z-Wave devices are fully compatible with the new version of Z-Wave engine (3.0)
  • In some cases, device adding/removing fails and gateway needs to be rebooted to retry.
  • Gateway connection is not available in the new engine version
* - does not apply to HC3L (Home Center 3 Lite)
