Cannot connect HCL3 as Slave in HC3 system
Tirana
I do have a HC3L system, which cannot be prepared/placed as a slave mode. Prepare home center to be as slave in the HC3L does not shown as available (is grey)
Can anyone help hot to put in slave mode, in order to connect to HC3
Hi @Tirana,
I would do these steps:
  1. Make sure both units are reachable.
  2. Update both Home Centers to 5.071 beta.
  3. Factory reset HC3L. -> Do not got to UI to complete Wizard.
  4. Connect in Connected gateways in HC3
Hello Tirana, good advice from Jakub.. On the top I will add to remember about selecting Z-wave engine 2.0 after recovery on HC3L. Currenly master - slave is not working on z-wave engine 3.0 which is selected by default after recovery on HC3L.
