Hello, We have a problem with or HCL
Frans08
Try ensuring that your router always gives out the same IP address to your HCL.  it may be called a reserved IP, allocated IP, or static IP depending on your router.
    Thanks for the reply. The setting on the HCL is DHCP, I'll take a look in the router. We have to reboot every 24 hours to be able to connect to the HCL via the app and via the web.....
