How to decrease Memory Usage. In my case - from 96% to 55%
Hi All,
Last weeks I checked that my system works with high memory usage.
I start to export memory data to Influx and check it with Grafana and results are not good - system mostly use 95-96% and even after reboot it start from 85%
FYI - I have 111 Z-Wave devices and 27 QA's, some of them pretty big
So, I wrote little scene to optimize my system.
  - disable all logs to history ( I use export to Influx and usually don't use HC3 history panel )
  - disable all Energy Panels reports
  - disable all devices which are hidden ( but have possibility to have some exclusion list )
  - disable all devices which are in special hidden room, which I call "hidden garbage" - parent devices are here and all unused childs also here
  - delete all history each run
Result - memory usage dropped from 96% to 55%. Not bad !
Scene here:
Warning - use it at your own risk!
-- write all hidden devices here which need to stay enabled. format: room/device name.
local exclusion             = { "desk/relay internet" }
-- room with all "garbage" devices
local hiddenRoom            = "hidden garbage"
-- set true if you don't need Energy Panel
local disableEnergyPanel    = true
function isInList(dev, list)
    for key, data in pairs(list) do
        if (tostring(dev) == tostring(data)) then
            return true
    return false
function setPropertyParam(id, prop, action)
    local data = {
      deviceId = id,
      propertyName = prop,
      value = action
    api.post("/plugins/updateProperty", data)
function disableDevice(id)
    api.put("/devices/"..id, { enabled = false } )
function transform(t)
    local res = {}
    for k, v in pairs(t) do
        local idx = v.id
        res[idx] = v.name
    return res
-- scene, device, system, user, profile, unknown
function deleteHistory()
    local timeNow = os.time()
    api.delete("/events/history?timestamp="..timeNow.."&objectType=device")
    api.delete("/events/history?timestamp="..timeNow.."&objectType=scene")
rooms      = api.get("/rooms")
rooms      = transform(rooms)
devices    = api.get("/devices")
for k, dev in pairs(devices) do
    deviceName = string.format("%s/%s", rooms[dev.roomID], dev.name);
    if dev.properties.saveLogs == true then
        print(dev.id.." is saving logs")
        setPropertyParam(dev.id, "saveLogs", false)
    if dev.properties.saveToEnergyPanel == true and disableEnergyPanel == true then
        print(dev.id.." is saving to energy panel")
        setPropertyParam(dev.id, "saveToEnergyPanel", false)
    if roomName == hiddenRoom and dev.enabled == true then
        print(dev.id.." is marked as hidden garbage")
        disableDevice(dev.id)
    elseif dev.visible == false and dev.parentId ~= 0 and dev.enabled == true then
        if isInList( deviceName, exclusion ) then
            print(dev.id.." is hidden, but needed.. skipping for now")
        else
            print(dev.id.." is not visible, but enabled")
deleteHistory()
print("Done...")
to run it every day at 3:30 put in left ( Conditions ) tab:
  isTrigger = true,
  operator = "match",
  property = "cron",
  type = "date",
  value = { "30", "03", "*", "*", "*", "*" }
Create backup without history
Restore backup
Memory usage will be much smaller.
Succes
//Sjakie
And ...
Kostya, if you remove all QAs is memory grow?
another question
if you export dump
in “process file” we can see CPU for each process and memory for each allocated process
you can see what for each QA fibaro core allocate memory from HC3 memory pool
Restore backup
Succes
//Sjakie
It’s not right to manipulate  with backups
first of we should api for clearing history
second we should have option(s) how we should keep history
and last but not least why Fibaro load all history to memory?
@10der, this is the way Fibaro works.
backup without history (Cleans perhaps more history as being done in API?)
restore and wallah meme usage back as it was before.
Dont shoot me, hahah
Its helping me to get mem down
//Sjakie
We are not ;)
Some of the things are being loaded to RAM but we are working on it to remove this entirely.
    //Sjakie
    I'm truly believe, that much better way not to generate extra garbage as first priority
    It will save some CPU time too, not only memory
    And scene can work in automatic mode and back-up and restore needs to be processed in manual mode, because some times Fibaro can go to Recovery console after restart.
