Hello from Belgium again
Europino
Hi all,
I am a new HC3 user, living in Belgium (Limburg).
My first project is to automate my 30+ years old Central Heater (running on oil or mazout as they say here), using a Fibaro double switch (one for the heater and the other for the pump and a Fibaro smart insert device to measure the water (in and out) and outside temperatures. Anyone here who did something similar? I will use the existing old on/off thermostat by connecting it to the smart insert, but want to replace it later on by a z-wave modern thermostat.
I can use some advice on which documents to read to get a quick start in setting up the devices, configuring them, playing with icons and using scenes (block programming) to automate the central heater.
Hmm perhaps it's time to replace the 30 years old heater?
welcome to the forum
psst better not say that you are from belgium.... there already to many people from belgium overhere :)
    It's just for fun, a learning project. Next summer I will replace the heater.
    There are tons of possibilities to indulge yourself with home automation.
    I agree with @akatar. Choose something that can't explode :P
