Fibaro RGBW Controller 2 wall switch connected to In1
SUPRA
Hi, I have installed the RGBW controller 2 which works differently to controller 1. I have a momentary switch connected to in1 which only operates the red led, how can I have all colours to come on from one switch input, on previous model all I had to do was set a parameter but I don’t know how to achieve the same with this new controller
Edited by SUPRA
  • 4 months later...
I solved this by triggering scenes, see below but ignore the double click functionality if you don't need it.
Guest Benrive
Hello @SUPRA.
You have to change some parameters and connect on IN3.  in this way with the button you turn on, turn off and regulate.  If you do this it will work as you want.  (this will do what I tell you but it will not change color).  Finally, create a scene by pressing 1 or 2 times on IN3 to put the color you want or activate a predefined mode.  If you need more detail tell me.
