Greetings from Hellevoetsluis (Netherlands)
tjeerdhage
After rebuilding a house from 1892 I started to use smart lightning.
Now i trying to make te house smarte with the HC 3r.
Goal is Next making a script for the ventilation. (low high switch)
I want to use netatmo for it (but at this moment I got an error)
Shower is already working
And data from EnecoToon
Monday I will Roote the Toon and then will use the data
Welkom Tjeerd :)
You have some nice plans. Automating the ventilation is also on my to-do list.
Good luck with rooting your Toon - should be easy to do! There are some nice
quickapps already around on this forum that you can use! (i do already)
Welcome
What kind of ventilation are you using?
Welcome Hellevoetsluis ! ?
    Akatar@ iam using smart wallplugs with stork zender ventilation. So can i change the speed
    Hello there almost neighbor, I live across the water from you. Building a special kind of domotica: floatmotica or naumotica. I will introduce myself to the forum in a separate post :-)
    Welcome @tjeerdhage and good luck with your automation!
