motion detection
sjstrobl
I own and use quite a few Fibaro motion sensors together with single/double/dimmer switches.
I like to multitude of parameters and I'm getting closer to what I want to achieve every day. Unfortunately I haven't really got there, hence I want some advise here to get there ;-)
I should add that I'm not using HCL but a raspberry pi running openhab. I'm trying to use associations as much as possible to optimize for latency and reduce air traffic.
Looking forward
Stefan
Edited by sjstrobl
Welcome to the forum Stefan. There are 1000 of posts about motion ?
    Which channel would be best to place questions / start to search on the interaction between motion sensors and dimmer 2?
    Stefan
    The biggest one :-)
    But I see you run OpenHab, so the posts will not always be of interest for you.
    Edited by SmartHomeEddy
    Looking forward
    Stefan
    Welcome on the forum.
    Did you also visit
    Hi Sjekke,
    thanks for the hint. Yes, I'm aware of the openhab community also :-)
    Regards, Stefan
    Welcome from Norway
    Welcome from Croatia ?
