Hello!
khvaal
As a new member I look forward to find out if I should change my well Working HC2 to HC3 at home and use the old HC2 at the cottage, in order to acces a wider selection of non-wave devices.
Kjetil
Welcome! I would say, "if it's not broken, then don't fix it". Keep the HC2 at home. Do your research on what controller to place at the cottage. Many people here would say not to use HC3, it seems more buggy than the reliable HC2. And ZigBee is still not available on the HC3.
Welcome @khvaal ?
I agree with @Tim__ , "if it's not broken, then don't fix it". :-)
There is always time to switch to HC3.
